NOTE: I did not create this program. InsaneMatt did.
His first post in this thread can be found here.
I'd also like to note that I didn't "find" this program; I am an ALPHA tester.
What is GameSave Manager?
GameSave Manager is a FREE program which allows you to backup, restore and even transfer your gamesaves to other machines.
It's great for those who like to share gamesave progress with friends/family, format frequently, paranoid about data loss, etc...
No longer do you need to rummage through loads of directories, trying to find your GameSaves; GameSave Manager does it for you.
Have a game that's not supported? No problem; using the "Custom GameSave Entries" you can define your own GameSaves for GameSave Manager to search for.
GameSave Manager does not come bundled with any "nasties" (adware, spyware, etc...).
Excluding it's optional "Check for Updates" and "Auto-Update" features, GSM doesn't access the internet.
Still not sure? Try it in a Virtual Machine and see for yourself!
Download:
You can download this program for FREE via the official website.
Officially Supported Games:
The "Officially Supported Games Database" is always being updated.
You can find a full list of officially supported games via this link.
As of 13/12/2014, there are 3039 Games supported.
Updating the "Officially Supported Games" database:
Spread the word:
Find GameSave Manager useful? Then please help spread the word by adding the following to your Signature:
[/CODE]
Feedback:
InsaneMatt is always grateful for suggestions, opinions (both positive and negative), etc..
Found a bug? Please let him know; after all it wont get fixed if no-one reports it!
Want a game to be "officially supported"? Let him know, and he will see what he can do.
You can contact him via this thread, the PM'ing system of this forum, the Official Website or the steam group.
Screenshots:
Removed due to being outdated.
Download:
To receive the update, do one of the following:
- Launch GameSave Manager with the "/update_db" commandline (requires you to allow GameSave Manager to access the internet to download and apply the update directly).
- Enable the "Auto-Update" function (again, requires GSM to have internet access).
GameSave Manager will then automatically update the database next time you launch GSM. - Launch GameSave Manager and click the "Check for Updates" button from the Main Menu (yes, you've guessed it... requires GSM to have internet access).
- Manually download the database update. Extract the gsdu file from the zip archive.
Now do one of the following:
- Double-click the "gsdu" file (requires the File Association with ".gsdu" files to be assigned with GameSave Manager).
...OR... - Run GameSave Manager with the following commandline:
"/open: %1"
Include the quotation marks around the commandline too!
Spread the word:
[CODE]
[center]Want to backup your game-saves? Introducing...[/center][center]
[url=http://www.overclock.net/other-software/594322-gamesave-manager.html][B][COLOR=GREEN]GameSave Manager[/COLOR][/B][/url][/center]
Feedback:
Screenshots:
