freeware suggestion
656 Views 10 Replies 9 Participants Last post by  decapitator
i need something that can burn music cd's and data dvd's. I've since upgraded to vista and i dont remember what i had on xp.
1 - 11 of 11 Posts
it didn't really work that well
itunes hahaha
can't itunes do that? I know it can for music but I could have sworn there is a setting in the control panel that allows you to use a dvd as a storage device too. If not then any windows OS should have the proper means of burning a data DVD built into it. Just look it up on google
ImgBurn. If you want to burn an audio CD, switch to CUE mode and drag & drop. If WMP can play it, ImgBurn can burn it.
If you want to drag & drop .flac files, you should get madshi's flac filters
Imgburn is my favorite, its what I install on customer machines that need disc writing software for free.
Go to Filehippo.com. they have a lot of freeware downloads.
Definitely Imgburn. Easy to use, fast, effective. And free.
I second what everyone else has said about ImgBurn. After being fed up with other free burning programs I tried ImgBurn and never looked back.
worked great, i would now recommend this program to anyone
1 - 11 of 11 Posts
