1 - 14 of 14 Posts
Anyone with a Freexer 7 Pro and a C2D. Post your idle/load temps and clocks if you have this. Im thinking of buying the cheap thing until my phase gets back from fixing
I've had both the scythe mine and the tower 112, at least for me the scythe 112 cools much better for about the same price, provided you have a good fan set up.
Power Squid
I hope this screenshot helps to give an idea of an average temperature.
Next time you have to re-position those cpuz windows a little better!
I'm running a E6700 at 3.3 GHz. at 1.45 volts with a Artic Freezer 7 Pro, and temps are around 40c idle, and high 50's under load.
That is about the highest I am going to run with air, temps just get to high for my liking. I am going to wait for water before I go any further.
Originally Posted by ThaWaxShop
Hmm how come everyone elses CPUZ displays voltage? Mine stays at like 1.2
in bios you have some options,like thermal option 1 and 2, and below another few options
the voltage to cpu goes up and down in function of your usage, you can disable the EIST function and then your voltage will stay the same whatever is your cpu/video usage
Discussion Starter #14
EIST and C1E are disabled
1 - 14 of 14 Posts
