1 - 12 of 12 Posts
Freezers are meant to keep what's inside it at a certain temperature, and because the food doesn't emit heat it's possible to do without having it constantly cooling the food. However a CPU does emit heat so the freezer would die in less then a day.
Freezer's pump is half-duty cycle. Meaning if running all the time it will burn out.
However, a window AC unit can be converted to a phase change unit.
And you know what freezer compressor is inside right?
Also, I was under the impression that one of the primary advantages of a rotary (as applies to our usage) is that it's much quieter than a piston type compressor. jes/no...??
You cant use fridge/freezer compressors in SS units. Only AC ones.
For the same reason that pc's can't be cooled in a fridge. The compressers in them are not meant to be "always on" The compressors in them only turn on when the temp gets too warm in them; therefore it would burn out in a few days
Originally Posted by Reflexive View Post
I'm assuming you didn't read the thread there Starbuck.
Mind telling us what makes a AC compressor different then a fridge one? You seem convinced.
Well like I said in the pm, I'm not gonna argue with a Hvac teh.
Was only going on what I was told
1 - 12 of 12 Posts
