For the past while I've had an issue with my system randomly freezing. Sometimes it would be when browsing with Chrome, one time while fiddling with Steam and on occasion right after I boot into Windows 7. Aside from the occasional freeze everything else seems okay- but Windows seems to load slower, although that could just be my imagination. Most games still work, from what I can tell. But the game I'm currently playing, Torchlight, freezes up quite often when hitting a loading screen. So, I've finally decided to swap out some components and nail down the problem! Problem is I'm extremely poor and thus have to figure out which component is most likely causing the problem- which is why I need your guy's help.
I've run Windows Error Checking on the hard disk and let it run overnight. I've run MemTest86 and got no errors. Lastly, I've reinstalled Windows 7 and updated all my drivers. When the system recovers it gives me the Windows has recovered from a serious error dialog. The BBCode is 124 which Google tells me is hardware related. The crash dump reads as follows:
My system:
Windows 7 Ultimate 64 Bit
AMD Phenom II X4 975 @ 3.60 GHz
NVIDIA GTX 460
Sound Blaster X-Fi GO! Pro
ASUS M4N75TD Motherboard
- Ryan Paul Fialcowitz
Microsoft (R) Windows Debugger Version 6.2.9200.20512 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\Minidump\080713-17378-01.dmp]
Mini Kernel Dump File: Only registers and stack trace are available
Symbol search path is: SRV*C:\Symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 7 Kernel Version 7601 (Service Pack 1) MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 7601.18113.amd64fre.win7sp1_gdr.130318-1533
Machine Name:
Kernel base = 0xfffff800`02c02000 PsLoadedModuleList = 0xfffff800`02e45670
Debug session time: Wed Aug 7 23:19:26.677 2013 (UTC - 7:00)
System Uptime: 0 days 0:00:07.269
Loading Kernel Symbols
Loading User Symbols
Mini Kernel Dump does not contain unloaded driver list
* Bugcheck Analysis *
Use !analyze -v to get detailed debugging information.
BugCheck 124, {0, fffffa800794f8f8, 0, 0}
Probably caused by : AuthenticAMD
Followup: MachineOwner
1: kd> !analyze -v
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
WHEA_ERROR_RECORD structure that describes the error conditon.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: fffffa800794f8f8, Address of the WHEA_ERROR_RECORD structure.
Arg3: 0000000000000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000000000, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
BUGCHECK_STR: 0x124_AuthenticAMD
CUSTOMER_CRASH_COUNT: 1
DEFAULT_BUCKET_ID: WIN7_DRIVER_FAULT
PROCESS_NAME: System
CURRENT_IRQL: 0
STACK_TEXT:
fffff880`031a16f0 fffff800`02ec2ca9 : fffffa80`0794f8d0 fffffa80`06aaa040 00000000`00000007 00000000`00000000 : nt!WheapCreateLiveTriageDump+0x6c
fffff880`031a1c10 fffff800`02da3e87 : fffffa80`0794f8d0 fffff800`02e1d2d8 fffffa80`06aaa040 00000000`00000000 : nt!WheapCreateTriageDumpFromPreviousSession+0x49
fffff880`031a1c40 fffff800`02d0b285 : fffff800`02e7eae0 fffff800`02c8123d 00000000`00000010 00000000`00000202 : nt!WheapProcessWorkQueueItem+0x57
fffff880`031a1c80 fffff800`02c81251 : fffff880`010d4e00 fffff800`02d0b260 fffffa80`06aaa000 00000000`00000000 : nt!WheapWorkQueueWorkerRoutine+0x25
fffff880`031a1cb0 fffff800`02f15ede : 00000000`00000000 fffffa80`06aaa040 00000000`00000080 fffffa80`069ab740 : nt!ExpWorkerThread+0x111
fffff880`031a1d40 fffff800`02c68906 : fffff880`02f64180 fffffa80`06aaa040 fffff880`02f6efc0 00000000`00000000 : nt!PspSystemThreadStartup+0x5a
fffff880`031a1d80 00000000`00000000 : fffff880`031a2000 fffff880`0319c000 fffff880`031a1560 00000000`00000000 : nt!KiStartSystemThread+0x16
STACK_COMMAND: kb
FOLLOWUP_NAME: MachineOwner
MODULE_NAME: AuthenticAMD
IMAGE_NAME: AuthenticAMD
DEBUG_FLR_IMAGE_TIMESTAMP: 0
FAILURE_BUCKET_ID: X64_0x124_AuthenticAMD_PROCESSOR_BUS_PRV
Machine Name:
1: kd> !analyze -v
Arguments:
Debugging Details:
CURRENT_IRQL: 0
STACK_TEXT:
STACK_COMMAND: kb
My system:
NVIDIA GTX 460
