1 - 4 of 4 Posts
My computers seems to feeze whenever i close out of internet explorer or firefox. Anyone guess as to the problem. Other than this it runs fine and dosent freeze while running other programs. Its seems to do it on certain sites and not others.
Go to "Start -> Run" and type eventvwr.msc then press enter (you can also go to "Start > Settings > Control Panel > Administrative Tools") then "Event Viewer" should be in there.
A new window "Even Viewer" will pop up... look under "System" and/or "Application" for items with red Xs that happened at the SAME time as your problem and list them here.
1 - 4 of 4 Posts
