Windows Vista 32bit.
Sig rig.
Freezes for about 5 minutes, black screen says failed -security options, screen comes back, repeat. Have to reboot.
Recent hardware changes: switched from HIS(1gb) to Asus 4870 (512). uninstalled drivers, reinstalled latest. After the 2nd crash I uninstalled and installed 8.11 drivers (the latest ones I found stable). Also installed xtreme Gamer sound card.
one in Event viewer on today (latest crash)
Log Name: System
Source: Microsoft-Windows-HttpEvent
Date: 3/17/2009 5:09:59 PM
Event ID: 15016
Task Category: None
Level: Error
Keywords: Classic
User: N/A
Computer: mark-PC
Description:
Unable to initialize the security package Kerberos for server side authentication. The data field contains the error number.
Event Xml:
<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
<System>
<Provider Name="Microsoft-Windows-HttpEvent" Guid="{7b6bc78c-898b-4170-bbf8-1a469ea43fc5}" EventSourceName="HTTP" />
<EventID Qualifiers="49152">15016</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2009-03-17T21:09:59.081Z" />
<EventRecordID>25122</EventRecordID>
<Correlation />
<Execution ProcessID="4" ThreadID="68" />
<Channel>System</Channel>
<Computer>mark-PC</Computer>
<Security />
</System>
<EventData>
DeviceHttpReqQueue
Kerberos
<Binary>000004000200300000000000A83A00C00000000000000000000000000000000000000000000000000E030980</Binary>
</EventData>
</Event>
Warning
1
Log Name: Application
Source: Microsoft-Windows-User Profiles Service
Date: 3/17/2009 2:07:27 AM
Event ID: 1530
Task Category: None
Level: Warning
Keywords: Classic
User: SYSTEM
Computer: mark-PC
Description:
Windows detected your registry file is still in use by other applications or services. The file will be unloaded now. The applications or services that hold your registry file may not function properly afterwards.
DETAIL -
2 user registry handles leaked from RegistryUserS-1-5-21-3663195757-1971576328-4261918285-1000_Classes:
Process 948 (DeviceHarddiskVolume1WindowsSystem32svchost.exe) has opened key REGISTRYUSERS-1-5-21-3663195757-1971576328-4261918285-1000_CLASSES
Process 1808 (DeviceHarddiskVolume1WindowsSystem32spoolsv.exe) has opened key REGISTRYUSERS-1-5-21-3663195757-1971576328-4261918285-1000_CLASSESLocal SettingsSoftwareMicrosoftWindowsShellMuiCache
Event Xml:
<System>
<Provider Name="Microsoft-Windows-User Profiles Service" Guid="{89B1E9F0-5AFF-44A6-9B44-0A07A7CE5845}" EventSourceName="profsvc" />
<EventID Qualifiers="32768">1530</EventID>
<Level>3</Level>
<Task>0</Task>
<Opcode>0</Opcode>
<TimeCreated SystemTime="2009-03-17T06:07:27.000Z" />
<EventRecordID>8485</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Security UserID="S-1-5-18" />
</System>
<EventData Name="EVENT_HIVE_LEAK">
</EventData>
</Event>
The other warning is the same thing, but not the process 1808, just 948.
