1 - 20 of 20 Posts
As title game crashes on the title screen
The screen with jason's face soon as I try to connect get the pic of the disc and connecting
Then freezes and I have to restart pc ?
Anyone any ideas to sort this ?
Filthy Casual
Is this on Steam? Did you verify the game cache? Do you have the latest drivers installed?
Please provide your system specs for members of the forum to better help you.
If you go to your profile, you can add your system specs in the 'Your Rigs' section (about halfway down).
Once you've added all your components you can click save and add. This will save your rig to your profile.
Next go to scroll down in your profile to the 'Your Forum Signature' section and click 'Edit Signature'
You can add your rig to your signature by choosing it from the drop down in 'Edit Your Forum Signature' screen and then hit 'Preview'. I believe it will then ask you if you want to save. Click Yes.
Reactions: THEROTHERHAMKID
Thanks I'll get that done next time I'm at pc
I7 6700 3.4
Palit jetsream 1080ti
16gb 3000 ram
Yes it's on steam I've verified game cache already
But still won't work
I've uninstalled my antivirus to try that
Still won't work
All other games work fine
Only thing I changed was the gpu from a 1080 to 1080ti
But nvadia experience should sort the drivers shouldn't it?
Thanks Mark
Do you run programs that have an overlay? aferburner OSD ect..
Filthy Casual
I7 6700 3.4
16gb 3000 ram
Still won't work
Thanks Mark
Not necessarily, please run DDU to uninstall all drivers and files associate with NVIDIA and reinstall the latest drivers on your machine.
This is something else to try before you run DDU.
Discussion Starter #7
Thanks I will try uninstalling drivers and reinstalling ?
Filthy Casual
You can try completely closing Afterburner (make sure it's not running in the background) and running the game before uninstalling drivers. Could be something as simple as the game not liking OSD overlays.
You'll need to COMPLETELY remove the driver and GPU software. Please read-up on DDU, install, run, restart, and reinstall drivers.
Just want to make sure you understand what I'm telling you.
Discussion Starter #9
Thanks will do
I've used ddu before but will have a read not used it for a while
Thanks I'll reply back when I've tried it
Discussion Starter #10
Tried it but didn't work
Still crashes
Last time I had probs like this I had to reinstall the easy cheat but I've tried that too ?
Filthy Casual
Still crashes
What's the "easy cheat"?
Filthy Casual
Sorry Easy anti cheat
Try removing/ disabling any third party application (Easy Anti Cheat included) that runs in the background while you game so we can track down whether it's hardware or software related.
Discussion Starter #14
This worked I uninstalled the easy anti cheat
Works fine now thanks
Filthy Casual
No problem.
Just curious. Any reason you installed Easy? Do you play competitively where it might be required? It not, I don't think there really is a need to have it installed. VAC does an OK job through Steam and most other games have pretty good built-in anti-cheat/ software now-a-days.
What games do you play where cheating is an issue?
Discussion Starter #16
No problem.
I think it installs with the game ? Not sure
Dead by daylight too I think
Main game I think cheating is a problem is cod ww2
Filthy Casual
Ah OK... makes sense. Yeah, but COD WW2 probably blocks Easy, anyway. That being said, I'd assume they'll patch and hopefully crack down on the cheaters in WW2 in the next patch.
Discussion Starter #18
Cheers bajer29 you've answered a couple of my posts
Nice 1
Where are you from?
Filthy Casual
Ohio, USA. Hence, Round on the End and High in the Middle - O hi O
Discussion Starter #20
Ha ha thanks for the help dude
Happy to get Friday 13th up and running again
Living in the US must be amazing
1 - 20 of 20 Posts
