From water to phase...
1366 Views 14 Replies 7 Participants Last post by  DuckieHo
Okie, so I have been debating this for the past week or so. Someone asked me why I don't do phase and why I do water still so I figured I would scope out what all I am looking at spending and what is good. My system is in my siggy, I would like to keep it the same in terms of speeds and such. What am I looking at spending and what am I looking at getting for a good loop that I can rely on for lots of gaming and every day use? Again, I know nothing about this so all help is appreciated XD. Also, cost is not a factor, I will do what I must when it comes to computer parts for my gaming machine XD. Thank you pplz <3
1 - 15 of 15 Posts
You don't just buy parts for a phase unit. You need to build one or pay someone to build a custom one for your system. (not sure if there are any in Canada who sell).
Price ranges $400-1000.
They eat 200-500w.
You need to insulate your socket area.
oy!
loop eh? i guess your thinking of a water chiller. as a phase unit will only cool 1 componet(1 cpu or 1 gpu, unless you use multiple evaps which will drasticly decrease performance). personaly i recomend a water chiller over a phase unit anyway. keep your cpu at -30c or keep your system at -30c(gpu, cpu, nb ect) as water chillers can be tuned for higher wattages much easier in my opinion.
http://www.xtremesystems.org/Forums/member.php?u=47698
only canadian builder i am aware of. he is also building a unit for someone i know.
Do water chillers also have to be built from scratch or are there prebuilt ones available?
built from scratch as far as i know
its a good hobby to take up, but it can get very expensive. its very easy to just spend over $500 on tools for hvac alone. plus you need to be certified, EPA in the us, no idea what it is in Canada if there even is any environment protection laws, another thing would be if he is going for low temp cascades and auto cascades they can quickly become safety hazards for a beginner. i would recommend reading these before beginning to think of building your own. http://www.xtremesystems.org/forums/...ad.php?t=54668
http://www.xtremesystems.org/forums/...ad.php?t=98591
basically its built from scratch anymore, you can use some aquarium chillers assuming there tuned for a high enough wattage, but they generally don't go below 5c. Chillers are easy to build as well, or you can ghetto mod an airconditioner, basicaly all you do is put the evap of the air conditioner in a cooler of anti freeze and use that as the Reservoirs of your water cooling loop.
They eat 200-500w.
I am certain that there is a pre-assembled phase change units.
http://www.ocztechnology.com/product...cts/ocz_cryo_z
http://www.xpressar.com/product/rsc1...-features.html
http://www.frozencpu.com/cat/l1/g41/Phase_Change.html
I don't know what the difference in performance will be, but I looked into getting one for myself.
There are definitely pre-built kits available but they are waaaay overpriced. If you are near Edmonton I can build you a rig. Or if you are willing to pay shipping, of course you can be anywhere in Canada. PM me and we can chat.
bwahahaha my words get to you that much eh? Yes, as all the others have stated... Phase is not a loop, its a single unit cabable of taking your heat source (CPU/GPU/NB) into sub ambients. it uses the same technoloy as an airconditioner or freezer, HVAC and Phasechange. I suggest getting a custom built one, only builder that lurks here is NoL and he's booked... basic single stage unit tuned to max load, gassed etc, will cost you around $600 USD + freight and customs... I've looked into it before, and someday I'll get one... but for you now, I'd say go look at a TEC, and fstfrddy's V8P waterblock
you can check out his site here send him an email... also check the for sale section for a 437W TEC and a meanwell PSU for it
it'd get your CPU sub ambient, add a little weight to your rig, but it may allow you to clock that CPU even higher
lets see here... #1... tuned for 120watts and nearly imposiable to find, 2x no!
#2 designed to keep ambient temp with r134a. uhh not what where after but it works(untill you force a cpu over 200watts!) so no
#3 built to handle around 200watts for $800.. uhh no. nol builds higher quality units that handle higher wattages for cheaper even!
there is no commercial sub ambient cooler these days, everything is basically custom made anymore.
fstfrddy's makes some dang good block both performance and aesthetically pleasing looking water blocks. the only problem is that the 437watt tec is actually only a 360watt. meaning its not good for quads. works great for dual cores though.
Are there any advantages of going sub-ambient? I can understand extreme cooling for benching and bragging rights, but doesn't hardware failure due to voltage come into play at one point or another, even though temps may be extremely low? I am not criticizing, I am asking. I have been playing around with some ideas of TECs and Phase, but I am kind of skeptical about using for daily 24/7 machines.
Yes, voltage kills hardware. But, more often voltage PLUS the resulting high temperatures are what kill hardware. That being said, the advantage of phase is being able to run high voltages farely safely. Bear in mind, "high" is a relative term.
voltage and temps don't kill ypur cpu(unless you reach the melting point of silicon of course)
quantum tunneling(aka "migration") is the killer. it rapidly degrades the transistors down to nothing.
what low temp does is one of 2 major things, #1 slows down the atoms orbiting in the transistor stopping quantum tunneling, #2 turns the chip into a super conductor making it much more efficient with energy, meaning at the same voltage as an air or water cooled setup you'll get a higher overclock.
Fair enough. I'll maintain my comment as it is good enough for our lot.
Just a point... voltage and temperature are factors in electromigration rate.
1 - 15 of 15 Posts
