Hello all,
I'm planning on mobo replacement.
I always used x16 2.0 gfx cards on my old x16 1.0 slot.
While i thought having a boost once using it on the new x16 2.0 slot, i discovered many links :
http://www.hardocp.com/article/2010/08/25/gtx_480_sli_pcie_bandwidth_perf_x16x16_vs_x4x4
http://www.techpowerup.com/reviews/NVIDIA/GTX_480_PCI-Express_Scaling/24.html
http://www.techpowerup.com/reviews/AMD/HD_5870_PCI-Express_Scaling/25.html
http://hardwareforall.com/hwdb/x16.html
http://hardwareforall.com/tt/nvidia2.html
Finally, i'm "shocked"...
Indeed, i always was conscious about bandwidths and always studying the best ratios to avoid such incoherences as using external classic hard drives @ USB3 enclosures ... a transport way completely "unused"...
Well, i admit have been disappointed by not having studied graphics cards bandwidths.
But, while i always found numerical values for any device (transfer speeds, bandwidth i/o slots, etc...), values for gfx cards seem so obscure...
While the pci-e bandwidth is know, i can't find the values for gfx cards...
Many values can be found anyway :
http://en.wikipedia.org/wiki/Comparison_of_ATI_graphics_processing_units#Northern_Islands_.28HD_6xxx.29_series
But, all articles/reviews state : "gfx cards are far from saturating pci-e 2.0 bandwidth"... Well, in which numbers is it stated ??
I can't find a clear & simple answer to the simple question : "which max bandwidth can be used / is needed by such gfx card model ?"
Furthermore, other paramters have to be considered (fps, etc...).
By the way, if i migrate from x16 1.0 to x8 2.0 : same performance ?
Indeed, question has to be asked : x16 1.0 bw = x8 2.0 bw, but i consider the fact that number of lanes can also impact performance (as asking differences between 1 * 2GB RAM or 2 * 1GB RAM).
Thank you very much for considering this.
Sincerely,
XZed
Sincerely,
XZed
