1 - 8 of 8 Posts
Anyone here used a reservoir with a frosted effect? Primochill makes one. I was thinking of making an arctic blue theme and figure the groundglass effect would look neat with blue Mayhem coolant.
Cool I will look into that.
Is the frosted reservoir have any degree of transparency that you can see color?
Case ***der
Originally Posted by Tempest2000 View Post
Do you mean 400 grit? I used 400 grit on my acrylic tubes and it looks great. Key is to go in one direction.
Sorry yes that is what I meant. 400 grit in one direction will give it a brushed look. Acrylic used in reservoirs is softer than acrylic tubing. It looks much better.
Discussion Starter · #8 ·
What type of res are you looking for? I have this EK one:
I was looking at PrimoChill CTR phase 2 D5 enabled.
1 - 8 of 8 Posts
