Hey guys. So it's here!
Pictures
I think I'll do a review later one once I've used it for a little bit. What I can say about it right now though, surprisingly, is that it's overall slower than my ACT LABS aluminum pad. I have a feeling that it's because the surface on the Frostpad is much finer, which you can see from the comparisons in the pictures I took. However, they claim that the pad will not wear; the same cannot be said for my aluminum pad, which has worn slightly on the side that I use it most. That hasn't changed the appearance of it physically, and in fact, it's actually made the surface even faster. So if you're looking for the fastest surface you can get, this isn't it. More on it later, though.
Edit: http://www.overclock.net/t/1628208/fastest-pad-mat/40#post_26046635
Pictures
