1 - 3 of 3 Posts
Ok, I'm trying to oc my i7, problem is whenever I up it from 20x 133 to anything else it beeps at startup and won't load. But I can OC if I change all my memory setting to "auto", instead of using 1600 2:12, 8,8,8,24 and 1t and 1.65 DIMM volts.
It's either one or the other, I can't do both together. Do I need to up my system volts to oc? It's on auto right now.
Does anyone have any ideas?
Couple things you will want to do overclocking an i7 920 with the evga x58 and corsair ram.
1. Don't use the 20x multi as it's a unstable multi. Use 19 or 21 if possible
2. you will want to put your ram on the 2:8 divider
3. you could need anything between +200mv to 350mv on CPU PLL VTT
That should enable you to hit 200 bclk with the i7 920.
1 - 3 of 3 Posts
