1 - 20 of 31 Posts
Razer Blackwidow for $59, which is $20 off the normal price. This is a good entry level mechanical keyboard.
I believe this is in-store only since it doesn't show the $59 online, but it's in the newspaper ad
Originally Posted by Blizzie;13138003
Any thoughts about this for $60? I'll never be able to choose what to get..
Well for $60 it's basically the cheapest you will be able to get unless you go with a used IBM Model M on ebay, which is a gamble since great/new Model Ms go for $100+
I think the razer is a safe bet on what your getting. It's around the same price as your typical dome "gamer" keyboards anyways.
Too Poor For This
I bought mine when Newegg had a $10 off deal for $70 and i've been loving it ever since. Love the Cherry Blues. I just wish I got the ultimate so I could have the back lighting but that nearly doubles the price :/
These use blue switches... which aren't that good for gaming. Not sure why razor claims they are "gaming" keyboards.
Brown switches are usually the most recommended for gaming, my XArmor is coming today.. I think I made the right choice. They cost about 3x more than this tho.
Discussion Starter · #11 ·
Originally Posted by Nexus6
This doesn't come with backlit keys, or does it.
Does not have backlit keys.
Yeah but I guess it all depends on the user. I prefer my buckling IBM keys over my cherry blacks even though I think most people would be the complete opposite. I might just end up buying this deal to try out the blues.
Too Poor For This
There is no such thing as a "gaming" switch. All switches are down to personal preference and that is it. The biggest flaw would probably be the lack of nkro.
Originally Posted by cmorin
nice find. exactly what I needed to convince myself to get one!
+rep
It is an amazing keyboard. The blues work very well. I have noticed the keys are getting worn down a bit. Seems a little harder to press.
...might just need to clean my keyboard.
Indeed. The BlackWidow only has 2KRO.
This is different with Cherry blue switches. Razer changed the press for gaming.
Just a note to everyone that this thing is massive, and would totally be non-ergonomic if you have a small frame.
I have one and I'm currently in the process of finding a tenkeyless because my arms almost makes a 180 while gaming and my right arm does a 30 while tying
If you're looking for a full keyboard, I would recommend the XArmor U9Plus that's on sale right now. It's probably a bit more than this+tax.
Edit: meant tax, not sh
1 - 20 of 31 Posts
