1 - 2 of 2 Posts
I have a bunch of these 92mm high speed PWM fans that are rated at 116 CFM (probably at full speed). Most of them are almost brand new, meaning they were pulled before they went into service so very little wear on the bearings. They are not silent by any means, but if your goal is to simply push a lot of air, these will do the job. They came out of a rack mount server and the wires are cut, so you'll have to solder or crimp on a lead head to connect them. They are PWM, and hence have 4 wires. They are rated at 12VDC/1.60A each.
If you're local to San Diego, CA, you are welcome to come pick them up. I can ship them within USA, just PM me your zip code.
Leader of the #1 [email protected] Team
YGPM
1 - 2 of 2 Posts
