Heatware: http://heatware.com/eval.php?id=68103
Recently switched to black fittings and all of those Chrome/Nickel shiny fittings must go. Some of the fittings unfortunately have flaked off shiny plating around nozzle tip end and/or bottom of G1/4'' threads and so the bare brass pokes through. Judge by yourself, check the pictures, I uploaded plenty.
The whole set (of what's left available) is priced at $65 (below half of the original price), most of them are in excellent condition, some have flaked off plating, but regardless, all work flawlessly and never leaked in my rig.
Listing of parts:
4x BP Shining Silver compression 1/2'' x 3/4''
5x BP True Silver compression 1/2'' x 3/4''
1x BP Black Sparkle compression 1/2'' x 3/4''
4x BP Shining Silver 45 deg elbow (high flow rotary) adapter G1/4''
2x BP Shining Silver 90 deg elbow (high flow rotary) adapter G1/4''
1x Koolance (thick Nickel plated) 5-way block with 3 Koolance Nickel slotted stop plugs
5x XSPC Chrome low profile stop plugs with a coin slot - PERFECT condition
5x XSPC Dark Chrome low profile stop plugs with a coin slot - flaked off plating on the wet side - I will give those free to person buying all of XSPC Chrome stop plugs.
1x Koolance SLI VID connector for GPU waterblocks with 1 slot spacing (cards in sandwich setup) - it shows some plating gone at the nozzle tip inside, works without leaks though
1x Koolance SLI VID connector for GPU waterblocks with 2-3 slot spacing (cards NOT in sandwich setup) - barely used, perfect condition
Shipping
Shipping is $5 USPS Small Priority Flat Rate box for the whole set all over United States (that includes HI, AK and PR).
Shipping to Canada for the whole set is $12 by USPS First Class International.
Payments
Payments via Amazon Payments (preferred) or Paypal.
Items located in New Jersey, USA.
Listing of parts:
Shipping
Payments
