1 - 13 of 13 Posts
Administrator
The FSB in the BIOS states its 200. If I rasied this on my PC (P4 3.2 Prescott LGA775, 800FSB) to 205 or 210 what speeds would it run at. Also if I raised it to that level would I need to up any voltage on it?
210fsb x 16 = 3360mhz
You probably wouldnt need a vcore increase for that, but if you do, you'd only need to take it up a single notch.
Administrator
Originally Posted by spookedjunglist
210x16 = 3360
and for those little increases no voltage necessary
Ah thats helpful so that would make it like a 3.4GHZ. If I increased it to that how much hotter would the computer become? (~46C load average, max load detected was 56C on a very hot day)
When I raised my for my OC I did it about 2 at a time checked the increase for my CPU in the system icon and then went a little higher. Look through the forums see what people have gotten their CPU up to and then try and get yours that high, but do it slowly. Run Prime 95 torture test when you think you have gotten it high enough and see if its stable. Also check your temp increase. When I increased my FSB in my BIOS it went up fairly fast but I was careful not to make a large jump. Read a lot and see what you think it can handle. I didnt have to touch my Vcore, or anything but we do have different systems. You will be able to tell if your system cant handle the OC. If you get problems post em and youll get answers.
Administrator
I will be getting 1.5GB DDR2 533MHZ RAM in August with a new cooling system (tower 112 and 2 tornado fans). I hope that will get me to 4GHZ when I get them. To get it to 4GHZ would I have to do something like 250x16
hard to say but you should expect a little more temp maybe hit 58-60°c
and thats a little hot by my standards but shouldnt hurt your CPU.
may become unstable and crash a bit more though
if you want to get some nice memory bandwidth get the bios update for your board and this should allow you to run at a 14 multi and that would give your memory a big boost.
but you would need some pc4600 or faster to use that bandwidth
...and also a processor that has that enabled....not all of them do.
Administrator
Discussion Starter · #12 ·
Originally Posted by ATVkid*AFZ*
yep, you can get a big boost from a bios update, as well as sometimes a more accurate temp reading...
I have recently upgraded my BIOS to 1006 (the latest)
good. you want to keep it up to the latest one, because that one's the most accurate, and lets you have the most options as well...
1 - 13 of 13 Posts
