So there's been a bit of talk about CoolBitts Icebox Full Immersion cooling kit for pc's up to 750W.
https://www.coolbitts.com/shop/icebox5-sys-1
First off, what do you think of this in general?
Secondly, I was thinking of building my own for considerably less than what they are asking for that kit.
From what I can see, a pump, radiator/fans, fittings, thermometer and a case (such as an aquarium of some sort) should be all that is needed.
https://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/25121
There's a great radiator.
https://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/60062
There's a nice pack of fans for said radiator.
https://shop.watercool.de/epages/WatercooleK.sf/en_GB/?ObjectPath=/Shops/WatercooleK/Products/30352
Dual Pump setup for plenty of flow.
https://engineeredfluids.store/products/ec-120
There's the proper immersion fluid, same used by CoolBitts
https://www.coolbitts.com/shop/icetray-matx
Tray to connect motherboard to. I would probably look elsewhere or make my own though, tbh.
Find a cheap enclosure and all required fittings. Less than half the price of the CoolBitts setup.
Here's a link to a review of the coolbitts kit if you haven't heard about it.
https://www.anandtech.com/show/1526...r-full-pc-immersion-with-the-coolbitts-icebox
Thoughts?
Thoughts?
