1 - 18 of 18 Posts
I love my P183 but I have to give it up for another build for the living room. As a result, I am in the market for a new case. This time, I want a full tower case that has sufficient cooling for all of my folding cards, 460 and 2 x 9800GT. Might be swapping to some 475's down the road. The potential to do water cooling is a huge plus, as it is something I am looking to try in the future.
Requirements:
- Cable management
- Good airflow
- Easy to clean filters are a huge plus
- Allowance for water cooling down the road also a plus
- Don't care about window and LEDs, either way is fine as long as the cooling is good
- Doesn't require modding
- Doesn't cost more than 200 USD
Cases I have looked at based on input from friends and looking around on ocn:
ATCS 840
HAF 932/X
NZXT Phantom
Silverstone Raven
TL;DR - Need a sub $200 USD full tower case with zomg amazing cooling potential and possibility for wc.
Thanks as always!
The HAFx would probably fit your requirements. It has very good stock airflow, can fit a 360 rad in it with no modification but it's at the top of your budget around $200. I don't have one, but I've heard the cable management is very well done and easy to do. I think all the intakes on the HAFx have filters as well so I can't imagine they are too hard to clean.
MEGABYTE ME
IMO Look for something with 10 Expansion slots when goin big. I wouldn't settle for less than 10
Discussion Starter #6
Does having a top exhaust matter that much? I've always read that bottom mount psu and having top exhaust = awesome for temps. Some of those suggested cases have 2 rear exhausts instead of one rear // one top like more "traditional" fan setups.
Full Tower Cases
-Corsair 800D
-Corsair 700D
-Lian-Li PC-X1000
-Lian-Li TYR PC-X200
-Lian-Li PC-A77F
-Lian-Li ArmorSuit PC-P80
-CoolerMaster HAF X
-CoolerMaster HAF 932
-CoolerMaster Cosmos Pure
-CoolerMaster Cosmos 1000
48" Mousepad Extremist
Get the Silverstone RV02 and 1-2 of these if you aren't lucky enough to get them stock:
http://www.directron.com/ap181.html
You will get HAF X cooling, without the HAF X's hideousness in your house.
Discussion Starter #11
In-win, ikonik, fenix are unavailable here.
Raven02 only has 3 drive bays but i need 4 so I guess that is out unless I can figure out how to hide the 4th one.
Right now it is down to HafX and the sub 200 lian li's I think. Was really hoping to be able to go with the raven over the HAF too *_*
Would it be feasible to add those AP's to other cases with 20CM fans like the HAFX?
Just pick up a SilverStone CFP53B HDD cage.
PC Gaming 1337 Enforcer
Discussion Starter #17
Sigh, so they don't have the Raven 02 in stock for another month or so. Apparently they just sold their last one on hand yesterday.
I'm wondering if I should just pick up the 932 and be done with it. Is the HAF X that much better or is front panel usb 3 the only thing it has going?
i Would choose Haf X because it has filters and i like the looks of it than haf 932... the new thing about haf X is that theres 9 Pci slots, air filters, 3.0 Usb, and maybe 2x 200mm fan on top? but they would only give u 1 200mm on top so u have to buy the other 200mm fan and put it on the top.. i would choose HAf X coz for me the spitfire uses 9pci slots so it would hit the bottom Psu and i cant point it up coz my cpu heatsink is not low profile
1 - 18 of 18 Posts
