Fuse
Purpose:The purpose of this build is to make a case to house my new personal server and media player. It will be sitting next to my TV most of the time so I want it to be unobtrusive and small enough that I can cart it around with me when going away from home. The server will be running 24/7 and running several services for uses on my home network and over the internet.
Design:To suit it's purpose the case must be small, to this end all of the components will be fitted in to very tight places, this means restricted airflow, I am only planning on having 2 case fans and so I will be sealing certain sections of the case so that I can direct the airflow over all components. As it stands I will not be using any expansion cards as they are not needed, however when designing the case I will keep them in mind so modifications are possible to include them at a later date. The case will be designed around a box frame with plates attached as the panels. I am choosing to construct the case out of aluminium due to its weight and malleable properties, this makes it very easy to work with.
Components:The following components were chosen for a number of reasons. The motherboard utilises one of AMDs newest processors dubbed "Fusion", it uses an E-350 APU which consists of a dual core AMD CPU paired with an AMD Radeon HD6310 graphics processor. This board was chosen because of its low power usage, physical size and the fact that the integrated GPU can output 1080P videos, this makes it perfect for 24/7 operation and media display. The power supply and RAM are both leftover parts from upgrading my main computer, the Western Digital hard drives are also coming from my main computer.
- ASUS E35M1-M PRO motherboard
- AMD E-350 APU
- AMD Radeon HD6310 integrated graphics
- 2x2Gb Kingston HyperX 1600MHz DDR3 RAM
- 500W no name PSU
- Samsung 500Gb Spinpoint F3 (boot drive)
- 1+2Tb Western Digital Green (media storage)
