Hi,
I'm planning to modify a rig to make it silent (<15~17 dB(A) ) at full load. For this, l'm planning to watercool my graphics card as the other components do not exceed 11 dB(A) in nominal conditions.
My constraints are as follow:
But I also have some questions:
- I need at least 2x 5 1/4" + 1x 3 1/2" (or 3x 5 1/4") slots for an internal drive, a LCD display and a smart card reader.
- I need 3x 3 1/2" HDD bay (for my current RAID5).
- I'd like NOT to change my CPU cooling (AC Freezer 13 pro) as it already complies with my needs.
- Finding an appropriate case for a watercooling setup (I'm planning to buy a Bitfenix Shinobi XL. If you have a better idea for less than )
- Decoupling the coolant pump to reduce vibration noises.
- Finding an appropriate WB for my graphics card (Heatkiller GPU X³ 560 "hole edition" full cover; already bought).
- Which coolant do you recommend me, knowing that I prefer a long-life (>3 years if possible) corrosion-protective biocide residue-free coolant over a cheap one?
- How do you cope with the coolant filling/maintenance when you have a radiator at a higher position than the reservoir one (radiator at the top of the tower)?
- What kind of tubing fixation do you consider to be the most reliable over time?
- Where can I find some data or a mathematic formula to know the cooling capacity in function of the following data:
- radiator size (Ive planned to buy a 3*120 radiator)
- radiator thickness (to be determined)
- airflow (in CFM or cubic meters per hour if possible)
- a coolant thermal sensor (already found)
- PIC16F877A to do real-time calculation,
- pwm regulators to control the WC radiator fans.
