1 - 5 of 5 Posts
I hooked my video card to my tv and the desktop is all fuzzy and i cant read anything ??
Lower the resolution to 800x600 or any setting comparable to it. My guess is the resolution is set too high. TVs don't display like monitors.
ATI multi-display says to make the resolution the lowest you can.
640 by 480 might be your best bet. if its not a plasma with high resoulution its goin to look sucky, well it did on my 32"
ive done this many times. if your tv is not an hdtv then lower the rsolution to 640 by 480. at this resolution you can watch movies and they will look liek they are playing from a dvd player. text will always suck though and appear fuzzy unless the tv is hdtv compliant and you are hooking up with a DVI connection. movies will be fine though.
1 - 5 of 5 Posts
