I know this is a crap card but sometimes it doesnt even run crap games without putting artifacts on the screen. I downloaded that coolbits registry patch thing and went to autodetect for the clock frequencies and it actually recommended a speed SLOWER than the factory settings. Any ideas why this would be?
Also in the AGP settings on the same panel it says the AGP config is determined by the capabilites of the OS. Under that it says the capability of the OS is 2X but still the optimal is set at 8X. COuld it be a setting in the OS that is slowing me down? Im running XP Pro With SP2? Or will the GFX card run at the optimal settings regardless.
Examples of a game that dont run prop is bad boys 2. Artifacts all over the place when there are more than a couple of peolpe on the screen. Is ok when just me and the surroundings. Hope someone can help as this has been annoying me for a long time now. The game is smooth enough though.
P.s dont know if this is related but in windows my screen will go off then come back on after a couple of secs.
Thanks
Thanks
