1 - 3 of 3 Posts
well ill be damed i didnt know that the fx line that there not locked lol i didnt know that ..anyways the fx 55 is clocked at 2.6 ghz and its overclockable too hmm..well check this out ..
http://www.extremetech.com/article2/...1679402,00.asp
The new 4000+ is made in exactly the same way as the FX-53, on exactly the same .13 micron manufacturing process, runs at the same 2.4GHz clock speed, has the same L2 cache size of 1MB, and is available only in socket 939 format. The one small difference between an Athlon 64 4000+ and FX-53; the FX line of chips allows the clock multiplier to be overclocked, while the normal line does not. Since we won't be overclocking our chips in this review, the two chips are interchangeable. ^^^^^^what a wuss lol ^^^^^^^^^
i would overclock it
Like the Highlander, there can only be one Athlon 64 FX processor on the market at a time....
anyways a good review...
1 - 3 of 3 Posts
