1 - 6 of 6 Posts
trying to overclock my new fx-55 proc. temps are going way high. hitting 48c @ 3 GHz. using volcano made by thermaltake plus as5. think that i may need to reapply the as5 or what?
Is this at full load? What is your voltage set at to achieve this overclock? If it is a load temp with aggresive voltage you should be happy with 48*c.
sry, i was doing a bit of boozing last night. voltage is at 1.52v (roughly). i am going to have to crank it up a bit more to get it stable though. its not passing through prime95 yet. i just didn't want to crank up the volts and pass 50c.<br><br>
and it idles at 38c
Monaro!! Stop using stock cooling on the fx 62 o_o.... your like torturing it. if i have a fx 62, ill use my zalman and an extra fan blowing on my zalman =)<br />
<br />
<br />
who needs liquid cooling =)
Your temps are fine, just dont go above 55C<br />
<br />
My FX-57 was idling at 37C on water...
1 - 6 of 6 Posts
