1 - 20 of 47 Posts
Anyone know the highest stable FX-60 overclock and how it was done (voltage, FSB, multi, etc)?
Each chip is different. 3.0ghz seems to be the limit.
Yeah, 3.0's about the limit for the dual core FX's.
Discussion Starter #5
There's gotta be higher. In the "cool" lab at school (-100 C) One guy got a FX-62 to just below 4.0 GHz. But I must admit, I cannot comment on his stability
Have you got four 1 gb sticks of ram? If so you won't be able to run 1T and that will affect your benches (and may hinder your overclocks slightly as well). I have an FX-57 in my kids rig (almost bought the FX-60 instead at the time) but the 57 was OC to slightly over 3.2 Ghz on air (temps were just tolerable at that OC). On phase the FX-60 has hit 3.3 Ghz (xtremeforums). On air, 2.9 is likely, on water, 3.1 running right at the wire.<br />
<br />
Besides are you looking for top "boot" speed or stable/benchable speed. Different thing entirely. The FX-57 will hit in excess of 4 ghz on cascade phase as well but its not like you can run it at those speeds for anything.
=/ 1t and 2t command timing for your ram.<br />
<br />
if you really want to see what the highest overclock is for your proc, just overclock it yourself. maybe you'll get lucky and get the magical lucky proc that'll hit 5 ghz........chances are no, but you can still get a high OC...<br />
<br />
but don't ask us for advice on it, just do it.
Discussion Starter #9
Dude I'm new here, still trying to figure out how to change the RAM speed, I've been told drop it (and multiplyer) and increase FSB, but when you're new to this it ain't easy. Also, if I overclock and my bios freezes, how do I get it back to normal and start again?
Please mudd be serious. The highest OC on phase I have seen (and I did a lot of research choosing between an FX-60 and an FX-57) is as i mentioned 3.3 on phase. Cavalry, if you got water, with some work you can probably hit 3.1 max. regarding ram timings, 1T is faster than 2T. Using 4 1 GB sticks with an amd board (nf4 controller) forces the ram into 2T mode. If you take out two sticks, you can run 1T (Suggested if you want to run benches).<br />
<br />
<br />
Resetting the cmos is simple, unplug the psu, and move the cmos jumper over for 30 seconds to clear it (Restores it to default). Place jumper back in place and it should boot fine.<br />
<br />
The first thing you can try is to increase the cpu multi from 13 to 14x. this will bring you up to 2.8 ghz without overclocking the ram. It should be stable. Then you can try messing with ram timings. Eventually you will have to clock down your cpu and clock up your fsb (Which will also overclock your ram as well). This is where you may need to add voltage to ram or cpu to keep it stable. Remember though that too much voltage can fry chips and it increases heat output proportionately. Check the FAQ's on this site for overclocking guides. There are some excellent ones.
Discussion Starter #11
I guess I'm also looking for stable speed (not top for benchmark) but top to run everything on.
Discussion Starter #12
Does pumping in voltage help in stability at higher speeds or no? Just asking cause my motherboeard has a jumper to get in the 2.X volts, if needed
<a href="http://www.xtremesystems.org/forums/showthread.php?t=59753" target="_blank">http://www.xtremesystems.org/forums/...ad.php?t=59753</a><br />
<br />
3.6 on a fx 62 and 3.8 on fx-60<br />
<br />
and in all honesty i wasn't trying to be a smartass <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> just trying to say that there's no real way in telling you the max of your proc. just check it yourself.<br />
<br />
if you don't know how to overclock read some of the reviews and how-to's. its more difficult than just switching a few numbers here and there.
Yes, I amended my prior post read that. With water, you should be able (especially with a dangerden system) to get to 3ghz stable at bearable temperatures. You will definitely need to up the voltage to keep the fsb increase stable for cpu and ram.
<tr>
<div>
Originally Posted by <strong>Cavalry</strong>
</div>
<div style="font-style:italic">Does pumping in voltage help in stability at higher speeds or no? Just asking cause my motherboeard has a jumper to get in the 2.X volts, if needed</div>
</td>
</tr>
</table>
</div>max voltage on air 1.6v or else you'll fry your proc.
Mudd, have you actually read the work logs on those overclocks? No offense taken but I've been a member there for awhile and those overclocks were "only" for benching purposes. Besides gloatlizard hit 3.875 on cascade phase <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> Cavalry has water and apparently is looking for stable "operating" overclocks.
Discussion Starter #17
Well I can get 3.23 semi stable, wasn't sure if pumping more voltage in would be guaranteed to fix it, or only help. Also, I have had my bios freeze out when ocing, (like can't change it). I ahve some wicked smart classmates (first degree in computer science or something) how can reset my bios to normal, but how is that done?
You can also look here for stepping and OC info....<a href="http://www.amdgeeks.net/insertstepping" target="_blank">AMDGeeks.net - your amd overclock source</a>
Cavalry, use the reset jumper on the motherboard beside the cmos battery. look in the manual that came with your mobo. make sure you unplug the cpu first and mother the jumper for 30 seconds, move it back and it will reset. IF you don't have the manual download it from the MSI website
Discussion Starter #20
Well its stable on 15X multi. I put it on 14X and increased the FSB and ran into freezing really fast. Anything above 3.23 was a nightmare. Never gone above 1.4 Volts, but have a jumper to do so IF needed. I do a lot of BioInformatic and protein crystal analysis (its my major) so I need stability, but I also wanna be able to do it fast. Some calculations still take hours, and if I can reduce this time, even slightly, thats more game time when the work is done. <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 20 of 47 Posts
