21 - 40 of 47 Posts
download cpu-z (its a free program), run it, post validation and supply a link.
Discussion Starter #23
I'll work on ocing more this weekend, and post my results. Then maybe I can get more help. BTW, where in the bios is RAM timings/voltage?
Discussion Starter #24
Any reccommended first steps I should take? Is this "Core Cell" software by MSI in windows a good guide (I can select different FSB's) or is it better to just use the bios?
Bios,And you OC with 4 gig?How many stick's 4?Ummmm.Screenshot plz?
Discussion Starter #27
At the risk of sounding learning disabled, how do I do a screenshot? And did you mean a screenshot of??
Discussion Starter #28
In ocing, is FSB more important then the multiplier? What is this 5/6 or 4/5 I keep seeing too?
Discussion Starter #29
ira-k,<br><br>
you sent the url AMDGeeks.net - your amd overclock source<br><br>
but I don't get any of the info its asking for. How do I find it out?
Screenshot of any benches.Like 3d 06,05,03,aquamark,super pi.
<div>Originally Posted by <strong>Cavalry</strong></div>
<div style="font-style:italic;">In ocing, is FSB more important then the multiplier? What is this 5/6 or 4/5 I keep seeing too?</div>
</td>
</tr></table></div>
5/6 and 4/5 is the memory divider.<br>
For the FX series, it is pretty recommeneded to run at a multiplier instead of FSB, (Especially on not-so-overclockable mobos, like that MSI of yours) so get that multiplier pumping! Also, voltage can help stability. I would only recommend about 1.55, since it is a very powerful CPU you have there.
And to do screenshot you press ctrl and alt and print,then open paint paste and save image in JPEG.Later when you reply the post open attachment in manage attachments and loaded.Good luck.
Discussion Starter #33
Thanks, I feel a little overwhelmed in new territory, hopefully I can do some printscreens/benchmarks on Sunday for you alll
Yeah I hope.You can maked.With that set up you can get the 10,000 in 3d 06 easy mean easy and great scores vs the C2D.And go to the top 30 GPU department.
Discussion Starter #35
Just wondering though, in 3DMark06, does the CPU test run slow for everyone? Like I get a good score (whatever it was) but it didn't run as "pretty" as everything else did
Yes is slow and freak most of the ppl/lol but that is the way is running benches in the cpu along.What was your score?
Discussion Starter #38
You see I figure my machine is close to this guys:<br><br><a href="http://www.amdzone.com/modules.php?op=modload&name=Sections&file=index&req=printpage&artid=245" target="_blank">http://www.amdzone.com/modules.php?o...page&artid=245</a><br><br>
I just can't understand the steps he went through to obtain the result. I know my cooling is far more elaborate (4-7L/sec flow rate) so I should be able to do it. ANyone care to help me?
Discussion Starter #39
Can't recall off the top of my head (@ school). Will be home Sunday (or monday) and will run it then.
Just an example this is 3d 06 with my card's and your's are better card's if you OC those monsters.And im in # 10 in the GPU systems in the forum.You can do better.That was with the cpu @ 2.8<br><a href="http://assets.overclock.net.s3.amazonaws.com/9/9f/9f3731ff_vbattach33936.jpeg"><img alt="LL" src="http://cdn.overclock.net/9/9f/525x525px-LL-9f3731ff_vbattach33936.jpeg" style="width:525px;height:420px;"></a>
21 - 40 of 47 Posts
