1 - 4 of 4 Posts
Im trying to push my 6100 to 5 ghz, and before i go any farther, i have a question about voltage. Does increasing the voltage hurt the processor with the extra juice, or is it just the increased temperatures you have to worry about? (I am already at 4.6 stable, at 1.4625 volts) thanks for your time!
Thanks, also, what program can i trust? Coretemp and hardware monitor both tell me my cpu core temp is 31-33c while speedfan say cpu is 46-51c. This is at above settings, running prime95 in place ffts, and with a 480mm radiator and a box fan pointed directly at the motherboard.
1 - 4 of 4 Posts
