1 - 8 of 8 Posts
i have it oc'd to 3.6 by just raising multiplier and for somereason it will drop down too 1800mhz according to cpuz
Testing...
All new CPUs/GPUs downclock under idle to save electricity. Run super-pi or give the CPU some sort of load and it will go to max clock.
There is absolutely zero effect on maximum performance, but it's best to disable it if you are doing massive overclocks.
To disable it, disable Cool n Quiet/C1E in your bios.
338
Now it just seems really strage to me the same of the cores would throttle down under 100% load. ive turned off those 2 settings.
No.2 in Gaming
hello,
that also might be turbo core ,i would disable that also.
and the c6 state on the cpu advanced tab
1 - 8 of 8 Posts
