1 - 20 of 119 Posts
FX-5000
Hello fellas.
Here is some eye candies for you. Some of you've seen this, else where, but thought it would be a good addition to the forum.
In search of lower temps.
For honesty purposes, the FX-9590 is hot. I don't mean it's warm or just hot, I mean hot!
I toyed with this cpu for some time. Learning the board and the chips abilities.
Much time has been spent with an automatic everyday user purchase and use scenario. (pretty much for me to game with
) and also to enjoy a guarantee clock speed of 4.7ghz and a multi core turbo boost of 5ghz.
Now I pulled the P-state list..... here it is
# of P-States 7
P-State FID 0x22 - VID 0x02 - IDD 18 (25.00x - 1.525 V)
P-State FID 0x1F - VID 0x02 - IDD 18 (23.50x - 1.525 V)
P-State FID 0x1D - VID 0x02 - IDD 18 (22.50x - 1.525 V)
P-State FID 0x18 - VID 0x0B - IDD 14 (20.00x - 1.412 V)
P-State FID 0x12 - VID 0x15 - IDD 11 (17.00x - 1.287 V)
P-State FID 0x8 - VID 0x25 - IDD 7 (12.00x - 1.087 V)
P-State FID 0x10C - VID 0x35 - IDD 4 (7.00x - 0.887 V)
WUT??
talking 1.52500v at only 22.5X multi.
Want truth?
This processor doesn't remain stable under manual overclock conditions and trying to under volt a Cpu VID of 1.52500v
It causes freezes or system hangs like a SSD or HDD is going bad..... It's actually just a low volt typical AMD hang. No errors in testing, no overheats.... just hangs.
To make a long story shorter as I'm pressed for time this evening.......
At stock 4.7ghz with turbo and all green enabled, truth be told this processor would heat soak my 120.2 X2 rad set up cooling only the Cpu. Also in recognition the water loop is old. Rads have many years on them. Usually only run 5 rad fans as I am still doing. So essentially I was seeing thermal throttling between 30-45 minutes of stress testing.
65c Cpu socket temp - throttles. 90c Core temp, board shuts completely off.
Cpu would drop to 4.5ghz. I never say this gaming.... my games seldom use more than 2 cores. I don't have SLI, and I play mostly DX-9 games, One of my favorites being Hawken to utilize some awesome physx. Running a GTX 760, frame rates are always good even full physx.
Any how.... I wanted to eliminate that 65c thermal throttle with the stress testing but in reality it never happens just browsing and posting pictures like I will be doing very shortly here.
Any how, the de-lid was a success. Generally speaking Cpu socket temps stay 45c. With the stress testing I can keep her under 60c and this IS dependent on ambient temps. Nice warm loop, needs a rebuild.... but I saved my lazy butt some time on that fun!
Heres pictures, would be very happy to answer questions. Please keep in mind this is a daily rig, I seldom overclock it (doesn't need it) and enjoy very much the better temps!!
that's interesting. I thought all amd chips were soldered?
Hardware Maniac
Damn that nice. Im sure it is soldered?
Nice work !
Some things got me surprised when comparing my O.C with your little monster. My trusty FX-8350 "only" need 1.464v~1.476v to be perfectly stable at 4.9 Ghz. All cores. Your cpu load vCORE uses 1.525v ?
Too much voltage to me.
Something tells me that your chip can undervolt a little bit.
Other, my socket temps throttling are 72ºc+. I never got bogged with throttling under this temp.
Perhaps a motherboard behaviour? I do have extra cooling in the N.B and Socket (Fan on the Socket behind the motherboard)
Anyway great chip and RIG ! Grats !
Hardware Maniac
Originally Posted by jclafi View Post
Nice work !
It a 9590 amd put a 1 years warantly on the cpu and it max voltage from factory is about 1.525v of what i know to be stable.
And 4.9 and 5.0 need completly different voltage anyways
FX-5000
Discussion Starter #6
All FX chips are soldered.
I've De-lidded the following soldered processors successfully with ok success. Couple of duds on the list here.
FX-6100 De-Lidded Working
FX-6300 De-lidded Working (contest prize giveaway)
FX-9590 De-lidded Killed x1
FX-9590 De-lidded Working (second attempt)
FX-8320 De-lidded Sold Working
Athon 5000+ unlocker FX-5000 Kept
970T De-lidded for a customer Working
1090T De-lidded Sold Working
965BE De-lidded Sold working
940BE De-lidded Sold working
9850BE De-lidded Sold working
9950BE De-lidded Sold working
FX-4100 De-lidded NOT Working
6400+ De-lidded Sold working
6400+ delidded working kept (2nd 6400+ delidded)
______________________________________________________________________
A mention on surface area and heat accumulation:
I found through many of these processors, the IHS plate was an accumulator more so then a dissipater'. Increasing surface area works pretty good for most air coolers with 95w chips and greater. Helps less for water cooling lads. The reason being the water block is already an accumulator of heat, the water is the dissipater. The heat transfer through solder is good, better than thermal paste, but when using solder, IHS plate then some TIM, you begin to slow the heat dissipation process thus having higher socket temps. I found bringing cooling directly to the source of heat to be outstanding performance. Dropping max temps enough to fully gain on average 100mhz or higher Cpu speed. In addition to this, I've also found de-lidding to bring Core and Socket temps much closer together and seemingly better stability while loading and general usage plus gaming.
Quotable answers:
Technically yes. I can however load test 1.49500v at 4.9ghz and it's stable until "eventual" low volt hang happens. Processor doesn't receive requested (needed) pstate voltage at xclock at certain time interval, it locks right up. No errors, no blue screens... just a simple hang. Not the end of the world, I've spent hours gaming, generally 2-3 hours and nothing happened, walk away for a few hours to come to a hung PC.
While running this chip on the bench with some chilling involved, 5600mhz benchmarking and gaming was pretty easy while maintaining much lower temps.
Also have done tweaking with sub 200 reference clock speeds and just had a joy of a time. It's a fun overclock with FX without doubt there's no more to be said with AMD FX processors.
So here's a picture 4875mhz 1.488v and some Cinebench running on the daily loop. This configuration also was likely to hang with some point of time, it's more a when then why. That dang VID is high up there.
I think Stilt has answered many questions on leaky transistors. All I know, this chip loves voltage and doesn't seem to leak as much as require it.
Hardware Maniac
Quotable answers:
What mean contest price giveaways? did you win it?
Should try a fx 8300 they are cheap
and yea ihs is worth nothing that why gpu dont have them
FX-5000
Discussion Starter #8
Yes FX-8300. Good chip. LN2 on sub 50$ motherboard.
http://valid.canardpc.com/cih7iw
I gave the processor away at a contest held at my HWBot team site ClassicPlatforms, IMOG was the winner of FX-6300
Hardware Maniac
Awesome
Poor mobo is the vrm are with ln2 too never really looked to know if they where on motherboard in o/c record I know gpu are.
FX-5000
Discussion Starter #10
Awesome
I don't know really. VRMs did fine. 2.0+ volts no problem. Only 2 cores, but none the less hit fast clocks.
Hardware Maniac
That pretty good
im building a pc for my grandma that play solitaire with a fx 8300 and a 8 phase mobo ahahahah im gone crazy
Hardware Maniac
You are young man to still have grand parents. Mine have been gone for a long time.
You'd be better to build de-lidded i3 eh?
What we can delid i3 oh well could be fun but i will have my h75 to put to some use and the 8300 was a good choice in my book ((( im going to drop some gpu in the build for [email protected] So the extra multithreaded perf would be nice
But yea a i3 would be cheaper
Nice run Shrimpy. We have the same motherboard and CPU and I set everything to Auto in my BIOS except for manual memory frequency and timings because if I touch anything else, my system hangs. And yes, 9590 is like trying to cool down lava. I usually get around that 724 score you see in orange, which is running at everything stock, 4716MHz.
Here:
Hardware Maniac
It me or a 9590 would be perfectly cooled with a h110i gt
I have a Corsair H105 w/dual Noctua NF-P12 PWM fans and it doesn't completely do the job. Stress testing is rough but in games and normal desktop use it's fine.
FX-5000
Discussion Starter #19
I had done a whole bunch of testing about this "system hang" issue. I mean I've loaded all kinds of overclocks, underclocks DOCP settings, loaded PC chip settings, up to 275 bus clocks, under 200 bus clocks...
Even had hard times with FID 0x18 - VID 0x0B - IDD 14 (20.00x - 1.412 V) and trying to under volt this here..... No good. Must be running 1.41200v or higher at 20x.
Then you look at VID for 22.5x and higher... requests 1.52500v-
If you can cool that 1.5250v VID, you'd be able to run all 8 cores at 5ghz all day long. But them temperatures......
Honestly this set up is for massive clocks with LN2. I'd be willing to bet most FX-9590 could hit 8ghz with CHVZ motherboard.
Hopefully you make grandmother aware her PC is going to be folding and pulling 600w at the outlet and her electric bill is going to increase.
Also is violation of EULA.
Re-distributing the FAH files or packaging the FAH files inside another software package in a attempt to install FAH with or without the user's consent is a violation of the EULA. http://folding.stanford.edu/home/faq/faq-policies
This comment H110i cool a FX-9590 for your 2000th post??
Umm No.
1 - 20 of 119 Posts
