1 - 7 of 7 Posts
The FX 5200 in my parents computer started making a huge amount of noise, The fan is the problem, I tried taking the HS off and the fan off the HS and getting rid of any dust in their computer and on the HS, but nothing worked. I think the fan may be getting overvolted. Feedback is appreciated.
OG Overclocker
Try putting some WD40 or something like that on the fan bearing.
Hmm, really wierd, after I put it back in the slot, it made about 5 minutes of noise and then it just stopped.
OG Overclocker
The RADEON in my dads rig did the same thing. A little oil quieted it down.
Is it XFX by chance?
my NB fan on my AI7's making a lot of noise lately... i'm going to put some WD-40 on a swab and do it that way. if you do this, make sure not to put some on directly, because you'll lube up the entire board...lol.
1 - 7 of 7 Posts
