1 - 4 of 4 Posts
ok......i assume that you are using coolbits to overclock your 5200....i don't recommend that u overclock it manually.....u sould see something called detect optimal clock frequencies click it.... it will set the frequencies best for your computer settings....
Sry cuz when i oc it using that button it gives me an unstable setting sry
Use a program like Rage3d Tweak. Up your core frequency 3-4 mhz then run a game and play for a few minutes. If you do not see artifacts, which are little quick blurs of color or blackness or lines on your screen, then minimize the game and increase 3-4 more mhz. Keep doing this until you see artifacts, then back it down 2-3 mhz at a time until you see no artifacts, this is your highest core clock overclock. Then repeat with the memory frequency.
And Coldstar, oc'ing manually is much better.
Rep me up if i helped!!
1 - 4 of 4 Posts
