FX55 CABCE 0516WPMW @3705MHz [[email protected] 1.5-2-2-0 / [email protected]]
6925 55
I would like to share my results with the forums
IHS Mod
Because of very high temps, I've modded the IHS by removing the manufacturer original thermal compound and replacing it with Artic Silver 5. This mod drops 10 to 15°C in full load
SYSTEM
FX-55 CABCE 0516WPMW core #484
DFI nF4 Ultra-D {501-2fix | 623-1 | 623-2 | 704-2BTA}
2*512 TCCD 507 | 2*256 BH5
1*Gb X800XL
Antec True Power 2.0 550W
Win XP Pro SP2 | Win 2k3
COOLING
Watercooling:
Pump Atman A-103 (1200l - 1.2m)
Radiator from Air-Conditioning {+ a Radiator BIX}
Homemade waterblock
Liquid chilling:
Compressor 1/4HP
Pecomark condenser
HX tube inside tube
Refrigerant: R402A
Evap temp: -20°C
Cascade:
2 * Rotary Compressors 1HP
First stage refrigerant: R290
Second stage refrigerant: R170
Evap temp: -98.5°C unloaded
OVERCLOCKING RESULTS
1) CPU Max Screen = [email protected]
2) CPU Max Stable = not yet
3) 3DMark01 SE
34658pts | 3205MHz @1.65V Chiller | BH5 267MHz 1.5-2-2-0 @3.7V | X800XL 450/590MHz | http://service.futuremark.com/compare?2k1=8930228
32551pts | 3031MHz @1.55V Watercooled | TCCD 303MHz 2.5-4-3-5 @2.8V | X800XL 410/555MHz
31884pts | 3001MHz @1.52V Watercooled | BH5 273MHz 2-2-2-5 @3.7V | X800XL 410/555MHz | http://service.futuremark.com/compare?2k1=8852131
30464pts | 3001MHz @1.46V Watercooled | TCCD 300MHz 2.5-4-3-7 @2.7V | X800XL untweaked | http://service.futuremark.com/compare?2k1=8847589
25990pts CPU Watercooled & TCCD at stock freqs | X800XL untweaked | http://service.futuremark.com/compare?2k1=8843244
4) Super PI 1M
24.234 | 3432MHz @1.65V Cascade controled temp | BH5 @264MHz 1.5-2-2-0 @3.7V
24.719 | 3414MHz @1.70V Cascade controled temp | BH5 @263MHz 1.5-2-2-0 @3.7V
25.375 | 3251MHz @1.55V Chiller | BH5 @271MHz 1.5-2-2-0 @3.7V
25.968 | 3138MHz @1.42V chilled C2H5OH | BH5 @261MHz 1.5-2-2-0 @3.7V
26.188 | 3133MHz @1.42V chilled C2H5OH | BH5 @261MHz 1.5-2-2-5 @3.7V
26.422s | 3113MHz @1.55V Chilled C2H5OH | BH5 283MHz 2-2-2-5 @3.7V
26.594s | 3082MHz @1.50V Watercooled | BH5 280MHz 2-2-2-5 @3.7V
26.609s | 3101MHz @1.52V Watercooled | BH5 282MHz 2-2-2-5 @3.7V
27.094s | 3080MHz @1.50V Watercooled | TCCD 308MHz 2.5-4-3-7 @2.7V
27.203s | 3050MHz @1.50V Watercooled | TCCD @305MHz 2.5-4-3-5 @2.9V
28.610s | 2944MHz @1.50V Watercooled | TCCD @310MHz 2.5-4-3-5 @2.8V
31.922s | 2612MHz @1.15V Watercooled | BH5 @201MHz 1.5-2-2-5 @2.7V
32.844s | 2405MHz @1.46V Watercooled | BH5 @267MHz 1.5-2-2-5 @3.7V
33.109s | 2405MHz @1.42V Watercooled | BH5 @267MHz 1.5-2-2-4 @3.7V
33.172s | 2406MHz @1.42V Watercooled | BH5 @267MHz 1.5-2-2-5 @3.7V
36.860s | 2156MHz @1.50V Watercooled | TCCD @308MHz 2.5-4-3-5 @2.8V
5) CPU-Z
[email protected] Cascade [email protected]°C
3517MHz @ 1.70V chiller [email protected]°C |http://valid.x86-secret.com/show_oc?id=79603
3439MHz @1.63V Chilled C2H5OH [email protected]°C | http://valid.x86-secret.com/show_oc?id=71814
3420MHz @1.55V Chilled C2H5OH [email protected]°C | http://valid.x86-secret.com/show_oc?id=70973
3300MHz @1.63V Watercooled | http://valid.x86-secret.com/show_oc.php?id=61962
3252MHz @1.50V Watercooled | http://valid.x86-secret.com/show_oc.php?id=61955
6) PiFast 4.3 10M
28.26 | 3133MHz @1.42V chilled C2H5OH | BH5 @261MHz 1.5-2-2-0 @3.7V
28.83 | 3139MHz @1.42V chilled C2H5OH | BH5 @241MHz 1.5-2-2-5 @3.7V
7) OCCT
3000MHz @1.39V Chilled C2H5OH
1 - 20 of 56 Posts
I can tell you what. Some nice steady hands on removing the lid off that FX-55 hey ?
some nice results there..
cheers..
and be happy not mad !
Awesome work man, how come you just didnt leave the IHS off altogether? You couldve had even better temps without it. Nice job on the ocing!
I was just thinking the same thing.....
thinking that the IHS would actuall hold in a little heat...as with out it like on the older AMD chips that having a little air being able to flow slightly around the chip and having direct contact with the heatsink would allow for better cooling...
wht did you use to stick the IHS back on?
Discussion Starter · #6 ·
cheers..
Thx mate!
In fact, the improvement of leaving the IHS off in comparison to sticking it back on isn't sufficiently significant to justify the risk of broking the core while it's naked. What causes the high temps isn't really the copper IHS but mostly the manufacturer thermal compound... if you substitute it with AS, or something equivalent (I'm also considering using liquid metal; but I really don't like it...), chances are high that you'll never experience a significant difference between this mod and the simple IHS removal.
Anyway, I'm using some kind of non-traditional cooling such as homemade waterblocks and thus I need to preserve safety.
Check this figure for temps differencies between stock IHS+thermal compound and IHS+AS Ceramic (with Air cooling):
In order to stick back on the IHS, I've used some kind of silicon usually used to make joins of sealing into engines. Actual on is called Loctite Autojoin.
I ran a 3DMark 01 in order to break 32K with the TCCDs
Very Impressive
Discussion Starter · #15 ·
Some new results of Pi compting
PiFast 4.3 10M
Super PI 1M
Discussion Starter · #17 ·
Some new results of Pi compting. Check these timings, there are really really tight!
PiFast 4.3 10M
I saw a 28.19s but it crashed and then rebooted immediately after and the saved .txt file didn't show the time...
Super PI 1M
Discussion Starter · #19 ·
Not high enough
Let me install a new pump for the liquid-chiller and I might be able to find some sufficient stability to pass Pi 32M or OCCT @3.4GHz or above...
Reactions: dangerousHobo
Discussion Starter · #20 ·
It seems me that I've a kind of bad luck guys!
(1) I've been waiting since the 30 December for 24 Opterons from my hardware components distributor, (2) received the chiller broken during the first shipping, (3) suffered from bad eBayer, (4) received the chiller again but temps were awful (required me to change the WB and the pump), and (5) now after some freezes the FX55 refuses to boot again and the 4 leds of the DFI are still on
1 - 20 of 56 Posts
