if after installing your cooler on your cpu you see that the temperatures are not really that all great and you are getting BSOD's double check your cooling block to make sure it's making full contact on your cpu...
Look for capacitors around the cpu, I had to rotate my block 90 degrees so that it would make contact. I also applied some better thermal paste than corsairs..
here are the pics.
I also added another fan for push pull and blue led
haha
after
here are the pics.
after
