1 - 7 of 7 Posts
Discussion Starter · #1 · (Edited)
from time to time my g pro wireless acts extremely sluggish like its going through mud (happening in both wired and wireless mode) my previous mouse was a deathadder made sure all the razer software was scrubbed from the system now when the gpro acts sluggish if i plug in my old g403 it starts acting normal again do i have a bad unit or is something going on in windows 7?
Probably is bad unit if you can't set to work.
I experienced something similar with MX Master but he was not gaming mouse.
But purchase Logitech G900 brand new for 90 euro was great investment.
From teasers and reviews I never expected he will be so good mouse.
I believe G Pro Wireless is maybe even better and probably your sample have some issue.
@JackCY its happening in both wired and wireless
whats weird is that plugging in my g403 sorts it so i'm wondering if its windows related or just a bad unit at this point just cant have a 150$ paperweight sitting around
Are you using that "G HUB" software from Logitech? I've seen people complain about it and write that it's not good to have it running (but I don't remember details).
nope ghub went the way of the dodo a long time ago using lgs but dont have it running when i dont need it (ie almost never)
1 - 7 of 7 Posts
