Originally Posted by ArmenianLegend
you wont be able to run it at 2000mhz anyways as ur cpu can not handle it. only thing u can do is lower your speed to 1600mhz with tighter timings
You sir should really not post things like this.............
Anyway moving on, real world no nothing you can eyeball and say "wow, that was fast!" type deal.
Synthetic, yes you will see bigger number and increases over the 1600mhz ram.
So depends on the price and what you are going to do. But the 2,000mhz will give you plenty of head room though.
