G.Skill 6GB (3x2GB) what's the difference?
503 11
Between this:
G.SKILL PI Black 6GB
and this:
G.SKILL 6GB
Both has the same timings but the regular 6GB one is over $100 cheaper.
1 - 12 of 12 Posts
difference is (i think) they just havent dropped the price on the PIs for some weird reason its not worth $100 more
The DIMMs you will receive if you order the Black edition kit will have more overclocking potential than the normal kit.
G.Skill bins their RAM very high meaning there's little-to-no OC headroom, but I assume because the Blacks are the performance series that they are binned so that there is more OC headroom, hence the price markup.
Is it worth the extra $$?
That's up to you!
Discussion Starter · #8 ·
Originally Posted by shoot2thrill
The PIs have heat spreaders so can likely be overclocked higher... still that doesn't justify an extra $100 on the price tag.
They both use the exact same heat spreaders.....just different color.
Senior Overclocker
Originally Posted by Tator Tot
Its a newegg pricing error.
They were within 10$ of each other the other day.
if so .. quickly get the 109$ modules!
1 - 12 of 12 Posts
