1 - 6 of 6 Posts
Hi,
Has anyone had a Memory DIMM just fail -with no errors?
My sytem posts, but the BIOS won't recognize one of my DIMM's when I'm overclocking.
I used these settings: http://www.overclock.net/intel-mothe...-thread-5.html posted by Xmisery (Thanks!) with HT on.
I'm on the latest BIOS 703, and have moved the DIMMS on my MB, so I believe its the DIMM - not the MB.
When I reset the BIOS to all Default, all 3 sticks are recognized and I get 6GB, but when I start to OC at some point my memory simply doesn't all get recognized.
The memory I'm using is from NewEgg: G.SKILL PI Series 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL7T-6GBPI - Retail
Item #: N82E16820231335
Any recommendations?
Thanks! Ziggard
I don't think I'm overclocking the RAM - as its 1600 - and I'm at 1531 - but I'm no expert. I just used the settings I referenced from a previous thread. All my settings are below, and I'd like to change the "vRAM", but I don't have that option.
Based on my settings below, what should I change?
Thanks!
Ai Tweaker
Target CPU Frequency: 2660MHz
Target DRAM Frequency: 1066MHz
OC
Ai Overclock Tuner[Manual]
CPU Ration Setting[21.0]
Intel ® SpeedStep ™ Tech[Disabled]
Intel ® TurboMode Tech
Xtreme Phase Full Power Mode[Enabled]
BCLK Frequency[191]
PCIE Frequency[100]
DRAM Frequency[DDR-1531Mhz]
UCLK Frequency[3063MHz]
QPI Link Data Rate[Auto]
DRAM Timing Control (Sub Menu)
1st Information: 8-8-8-20-4-59-8-6-20-0
DRAM CAS# Latency[Auto]
DRAM RAS# PRE Time[Auto]
DRAM RAS# ACT Time[Auto]
DRAM RAS# to RAS# Delay[Auto]
DRAM REF Cycle Time[Auto]
DRAM WRITE Recovery Time[Auto]
DRAM READ to PRE Time[Auto]
DRAM FOUR ACT WIN Time[Auto]
DRAM Back-To-Back CAS# Delay[Auto]
2nd Information: 1N-51-53-53
DRAM Timing Mode[Auto]
DRAM Round Trip Latency on CHA[Auto]
DRAM Round Trip Latency on CHB[Auto]
DRAM Round Trip Latency on CHC[Auto]
3rd Information: 5-5-14-10-10-10-7-6-4-7-7-4
DRAM WRITE to Read Delay (DD)[Auto]
DRAM WRITE to Read Delay (DR)[Auto]
DRAM WRITE to Read Delay (SR)[Auto]
DRAM READ to WRITE Delay (DD)[Auto]
DRAM READ to WRITE Delay (DR)[Auto]
DRAM READ to WRITE Delay (SR)[Auto]
DRAM READ to READ Delay (DD)[Auto]
DRAM READ to READ Delay (DR)[Auto]
DRAM READ to READ Delay (SR)[Auto]
DRAM WRITE to WRITE Delay (DD)[Auto]
DRAM WRITE to WRITE Delay (DR)[Auto]
DRAM WRITE to WRITE Delay (SR)[Auto]
*******Please key in numbers directly!*******
CPU Voltage Control[Manual]
CPU Voltage[1.25000]
CPU PLL Voltage[1.80]
QPI/DRAM Core Voltage[1.23125]
IOH Voltage[1.14]
IOH PCIE Voltage[1.50]
ICH Voltage[1.20]
ICH PCIE Voltage[1.50]
DRAM Bus Voltage[1.64
DRAM DATA REF Voltage on CHA[Auto]
DRAM CTRL REF Voltage on CHA[Auto]
DRAM DATA REF Voltage on CHB[Auto]
DRAM CTRL REF Voltage on CHB[Auto]
DRAM DATA REF Voltage on CHC[Auto]
DRAM CTRL REF Voltage on CHC[Auto]
Load-Line Calibration[Enabled]
CPU Differential Amplitude[800mV]
CPU Clock Skew[Delay 300ps]
CPU Spread Spectrum[Disabled]
IOH Clock Skew[Auto]
PCIE Spread Spectrum[Disabled]
CPU Ratio Setting[21.0]
C1E Support[Disabled]
Hardware Prefetcher[Enabled]
Adjacent Cache Line Prefetch[Enabled]
Intel ® Virtualization Tech[Enabled]
CPU TM Function[Enabled]
Execute Disable Bit[Enabled]
Intel ® Technology[Enabled]
Active Processor Cores[All]
A20MDisabled]
Intel ® SpeedStep ™ TechDisabled]
Intel ® C-STATE TechDisabled]
Old school
Originally Posted by ziggard
Hi,
Thanks! Ziggard
It seems to be a common issue with Asus X58 boards. So it is in fact the board, not the memory. You need to change some settings.
the vRAM is DRAM Bus Voltage in that BIOS, but you're at 1.64 with looser timings and lower frequency than the stock RAM spec, so it's not that
try increasing the QPI/DRAM core voltage to 1.3v and see if you still get errors; if you don't that's your solution, and you can work on lowering that voltage
you may need to increase CPU PLL to 1.88v, and since you're using CPU clock skew, change the IOH clock skew to the same, I think that's recommended
also, not sure if it makes a difference, but put the QPI Link Data Rate to the lowest value from Auto
play with that and see what you get
Discussion Starter · #6 ·
Thanks for the great tips. I did make many changes based on the great recommendations, but at last this morning, I'm again back down to 4GB of memory.
Would it help if I had my CPU down to 3.6Ghz? Any other recommendations?
Thanks for your help!
1 - 6 of 6 Posts
