1 - 11 of 11 Posts
Hi,
I have this memory here below....
CORSAIR XMS3 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C9
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820145222&nm_mc=OTC-sho6b0tCA&cm_mmc=OTC-sho6b0tCA-_-Memory+(Desktop+Memory)-_-Corsair+(XMS+Series)-_-20145222
and i want to replace it with this....
G.SKILL F3-17600CL7D-4GBPIS PC3-17600
http://www.newegg.ca/Product/Product.aspx?Item=N82E16820231322&Tpk=G.SKILL%20F3-17600CL7D-4GBPIS%20PC3-17600
I have a Phenom II 955 OC to 3.9GHZ on a MSI 790FX-GD70, is it worth it getting that memory?
At $150 for 2x2GB not at all. Aside from 7-10-10 being ripoff timings, your 955 will probably not get there anyway.
Just spend on a cheap set of 2x2GB (or 2 sets for 4x2GB); a good choice would be G.Skill Ripjaws 7-8-7 on NCIX for $63.55 after price match.
Discussion Starter · #6 ·
I found a buyer for my ram and will use the money to buy a new set but i feel bad going from 6GB to 4GB.... how about 8GB
? Which one of these would be a good choice?
http://www.newegg.ca/Product/ProductList.aspx?Submit=ENE&N=40000147%20600006069&IsNodeId=1&Description=g%20skill&bop=And&Order=PRICED&PageSize=20
I think i'll go with these....
G.SKILL F3-12800CL7D-8GBRH Ripjaws PC3-12800 8GB 2X4GB DDR3-1600 CL7-8-7-24 1.6V Memory Kit
After selling my memory i'll just need to add 60$ to buy them and i'm starting to use CS5 and 3D softwares like Maya and 3DS 2011 a lot so 8GB will be better then 6GB for me.
Am i right here?
Discussion Starter · #9 ·
Originally Posted by angeluszero;11927607
these are 1333mhz and the ones i posted are 1600 with quite low timings.
Use those G.Skill PI Series @ 2000 7-9-7-21.
Yes but what I'm trying to say is that they are probably capable at running the same timings for a good pit less money.
1 - 11 of 11 Posts
