Are you just trying to boot or are you aiming to get it fully stable?I'm running on 6200 without any issues, also was able to gain M/T up to 6400 but with TCL 32; DOCP I and II work, but I'm trying to overclock RAM to find the best timings.
Could you please share your timings?Are you just trying to boot or are you aiming to get it fully stable?
Just reduce timings and then test for stability, y-cruncher VST and FFT are good for that.
GSkill support,The motherboard has been tested capable of DDR5-5600 with 64GB:
RAM Configurator - G.SKILL International Enterprise Co., Ltd.
Find compatible memory kits for your motherboard. Just select the motherboard from the dropdown list and click on Search for a list of compatible G.SKILL memory kits.www.gskill.com
The memory kit mentioned does not have AMD EXPO, so you can enable DOCP and set DRAM Frequency to DDR5-5600 to see if it can work well. If not, it may be best to exchange for a kit in the list above.
This failed after 6 hours of stability testing (y-cruncher):Could you please share your timings?
I couldn't boot with tCL at 30 last time i tried.Is TCL make a big difference in DDR5 as in DDR4?
I see all your TCL's 32 and higher.
This is 1st setting I tried to move down, from CL30 to 28 and this is why I'm not going to 6400 and higher, on CL28 I have no BIOS post.
intel is faster working with RAM, I have another system i9-13900K with 6600Mt/s TCL 30, and read and writes over 100Gb.I got 25% better read speed with only a few timings optimized @ 6400 MT/s
I have tighter tRAS (50) and higher tREFI and that's the only timings i see were mine were set for higher performance than yours.
I guess aida64 favors raptor lake over zen4.
