1 - 5 of 5 Posts
I have a Benq GW2760HS that I love - great color, perfect blacks etc, and I don't need/want more than 60hz for gaming.
But I would like G-sync so I can move around freely between 30 and 60 fps.
But it seems most G-sync monitors are either terrible, expensive, or plagued by QC issues.
This monitor cost around £200.
Is there a G-sync monitor that could match the IQ of this monitor? (it's a VA panel)
Is there a G-sync monitor that could match the IQ of this monitor for less than 3 times the price or some other ludicrous sum?
I have the same monitor! But why do you want to move between 30 and 60 fps?
If you're happy to game at 30-60fps at 1920 x 1080 and want a relatively affordable model that is somewhat similar to the GW2760HS, then you should consider moving to AMD. I don't know what GPU you use and how much you'd fetch for it, but with FreeSync over HDMI Samsung (and likely BenQ later on) will have a range of models that will offer the sort of experience you're looking for.
Lenovo Y27g supposed to come out in June for 550$, similar panel but with G-sync and 144hz.
There are no 60hz VA panels with G-sync
Discussion Starter #5
I suspected as much. Seems to be far more choice with Freesync than G-sync. I have a GTX970 but am very willing to look at AMD Polaris when that's out, specifically for this.
Don't mind if it's 1080 or 1440, but I only need 60fps.
1 - 5 of 5 Posts
