1 - 4 of 4 Posts
Hello guys. I cant find G-sync anymore in "manage 3d settings" in nvidia control panel under "vertical sync". it completely disappeared. has anyone else seen this before? G-sync doesnt even show up on the "Select a task" section of nvidia control panel either.
What the heck happened..
Originally Posted by Kinaesthetic View Post
Turn off display and computer, disconnect DP cable from the display. Then reconnect DP cable to monitor and then boot your computer up. Had this happen once to me, and it hasn't happened since.
awesome. worked like a charm. thank you
1 - 4 of 4 Posts
