1 - 5 of 5 Posts
Hi All,
I am running into a predicament here! Between the two boards their isn't much of a price difference $20-$30.
I guess I am asking what are the pro's and con's of each board.
I was also looking at the Maximus V Extreme, but its $100 more that both boards!
Need help with this as I want to buy a motherboard asap.
Thanks
G1 has 4-way SLI support, MVF doesn't.
G1 has 6 phase doubled to 12 VRM design, MVF has 4 phase design doubled to 8.
G1 has Creative codec and Killer NIC, MVF has SupremeFX.
Thanks for the reply.
In terms of overclocking which would be the better board to go with.
I want to get my 3770k to 4.8Ghz. The system will be watercooled btw.
Im sourcing all the components atm, and I'm running into a brick wall with the motherboard lol.
No idea. G1 should be better hardware wise, MVF might have better tweaked BIOS.
If you don't care about 4-way SLI support, consider UP5-TH.
1 - 5 of 5 Posts
