1 - 2 of 2 Posts
Hello. I need to upgrade my cpu (so I will change my mobo and my ram also). I have an old Q8300, and I'm thinking about buying a G4400 (I don't want to spend much).
Will there be any bottlenecking issue with this cpu and my MSI GTX750ti?
Will this build play games (like battlefield 4 and GTA 5) at medium-high settings at 1440x900 at 60fps (or possibly never under 30)?
Thanks in advance
if you're really on a shoe string budget, just make sure you get 8gb of ram or more and you're set.
Had a g3258 at 4.3 ghz and had literally no difference between my i5 and it in gpu bound games, although had to get workarounds for dual cores in a few games in order for them to start. That's one of the biggest drawbacks going with duals imo
BF4 multiplayer? In BF3 mp my g3258 could only get around 80 fps though if remembering correctly, settings didn't matter, bought the i5 and it got around 200 on low.
1 - 2 of 2 Posts
