I dont have one, but whats the issue you are having? Most laptop issues arent model dependent. If you give us some idea of whats going on, we can do more to help.
Just to preface, most laptop power issues end up being a hardware issue as they are well before the OS loads. So it is very possible you have a bad system board, bad charger, or a broken button. but since you didnt say whats actually happening its hard to say.
Just a suggestion if its an issue where the system doesnt want to boot. Pull the battery out, pull the AC Adapter out, and then hold the power button for 5-8 seconds. This will reset the PMU (power management unit) which controls the powere.
Another thing you can try, I know it works on some laptops, is try booting the laptop with only AC power and no battery. If its a 'smart' battery and its going bad it can interfere with the power on process but once removed the computer is able to boot.
Likewise if you normally power on with it plugged in, try without it plugged in. A bad AC Adapter can also cause power on issues.
Those are just a couple places to start. I cant say it enough though, give us some more information so we can try to give better help thats oriented more towards your issue.
