Ok, so I just finished installing Vista X64 on my new build and I downloaded the F9 BIOS from Gigabyte's site to update my BIOS to it (duh).
It downloads as a self-extracting archive, then when I try to run it, it tells me something about not being supported on that version of Windows, and that I have to check if I downloaded the correct file (for x86 or x64). However, on Gigabyte's site, there is no separate version for x64. Does the BIOS update program not support x64? Any ideas? :s
