It should work but looking at reviews on newegg, it seems that alot of people have compatibility issues between the motherboard and the RAM modules. I suggest you test it out when you recieve it and if there's any issues, you could send it back to ncix but i believe they have a 15% restocking fee on non defective items...
Otherwise, everything looks normal, it's a triple channel motherboard so it should be compatible in that regard.
Good luck!
Good luck!
