1 - 19 of 19 Posts
Nowhere can I find information gainwards volt mod for the 9600 GT PCB red: (
whether someone helped to raise the voltage to the gpu, overclock my card is not high, only 700 mhz on gpu, I have a 500 watt power supply
· Retired Benchmark Editor
Got a pic of the back as well?
Just pencil mod it. all you have to do is go to the local art shop. Buy a thick pencil and draw a line from a lower resistance resistors to your GPU.
It works because grafit is conductive. So it moves the electricity with out a wire or soldering ETC ETC
Mef, what are the numbers on the ICs I've labeled?
· Banned
..should be an APW7088.. just different design PCB from their other version. Double check the IC as Pizza mentioned though.
**could be RT8802A i suppose as well..though unlikely with only 2x power phases I think..
..nope.. its a APW7088..almost 100%
Discussion Starter · #12 ·
Those photos downloaded from the internet, I'm sorry but these are not pictures of my card, i thought it's the same card gainwarda.9600gt red PCB. Tomorrow I'll do a new photo camera, my card
Got some more work to do before we know where to mod.
I don't have any datasheets with 5383. Looks like an ISL, but I'm not sure...
1 - 19 of 19 Posts
