Gaming & Folding?
288 Views 5 Replies 5 Participants Last post by  Lumi
i use gpu2 to fold 24/7 except for when i game because i only get 3-4 fps is this normal?
1 - 6 of 6 Posts
It's normally best to pause for gaming.
Yes, the GPU client will use a lot of your cards processing power and will therefore cause slower than normal game play.
Isn't it only supposed to use the % that isn't being used when you're gaming, so that if you're using 100% then it will completely back off or is that just true for your cpu?
Yeah and Cool 'n Quiet is suppose to use 100% of your system when the system calls for it.
Things don't always work out.
I play TF2 on max settings while folding, and I've played Crysis on the usual settings with a 3-4 FPS loss, which never really hurt because with the settings I played I had a good FR overall.
1 - 6 of 6 Posts
