Actually the psu price is $209 in newegg, and for the build 750W is big enough even with OC cpu and SLi gtx 780.
If you use the 2nd and 4th slots then you wont have any clearence issues. 850 watts will be more then enough even with overclocked gpu's. As for the cooler, you dont need to maintain it but i can understand about the pump failing.Originally Posted by eric8412
I was interested in the phantecks air fan because it's quieter and don't have to worry about maintenance or failing pumps. Would that g skill ram be able to fit under the air cooler? It needs low profile. Would the 850 watt be enough to over clock the sli gpus as well? Don't want to run into energy problems..
Thanks for the responses!
